system switch fibre-channel refresh
Refresh back-end fibre-channel switch info
The system switch fibre-channel refresh
command triggers a refresh of the SNMP data for the MetroCluster fibre-channel (FC) switches and FC-to-SAS bridges. It does not do anything if the refresh is already going on. The FC switches and FC-to-SAS bridges must have been previously added for monitoring by using the system switch fibre-channel add and system bridge add commands, respectively.
The following command triggers a refresh for the FC switch and FC-to-SAS bridge data:
cluster1::*> system switch fibre-channel refresh cluster1::*>
