template copy
Copy a template
Use this command to copy an existing template. The copied template becomes a readwrite template and can be customized using template parameter family of commands.
-name <template name>
- Name of the template-
This parameter specifies the name of the template.
-destination-name <template name>
- Destination template-
This parameter specifies the name of the destination template.
The following example copies template1 to template2. The template2 will be a readwrite template:
cluster1::> template copy -name template1 -destination-name template2
