vserver fpolicy engine-connect
Establish a connection to FPolicy server
The vserver fpolicy engine-connect
command connects an FPolicy server to a specified node. Connecting the FPolicy server to a node enables FPolicy processing, providing the FPolicy configuration is complete. Before connecting an FPolicy server to a node, you must configure FPolicy by completing the following tasks:
Create an FPolicy event
Create an FPolicy external engine
Create an FPolicy policy
Create a scope for the FPolicy policy
The FPolicy event and external engine must be attached to the FPolicy policy. |
The FPolicy policy should be enabled. |
-node {<nodename>|local}
- Node-
This parameter specifies the node that you want to connect to the FPolicy server. The value local specifies the current node.
-vserver <Vserver Name>
- Vserver-
This parameter specifies the Vserver that you want to connect to the specified FPolicy server using the specified FPolicy policy.
-policy-name <Policy name>
- Policy-
This parameter specifies the name of the FPolicy policy that is attached to an external engine.
-server <IP Address>
- Server-
This parameter specifies the FPolicy server to which you want to connect the node. The specified server must be present in the external engine configuration of the above specified policy.
The following example connects an FPolicy server.
cluster1::> vserver fpolicy engine-connect -node FPolicy-01 -vserver vs1.example.com -policy-name p -server 1.1.1.1 cluster1::> vserver fpolicy show FPolicy Server- Server- Vserver Policy Node Server status type --------------- ------------- ------------ ----------------- -------------- ----------- vs1.example.com p FPolicy-01 1.1.1.1 connected primary
