lun mapping show-initiator
Show the LUN mappings to a specific initiator
The lun mapping show-initiator
command lists the LUNs which are mapped to an initiator group which contains a specific initiator.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]
- Vserver Name (privilege: advanced)-
Selects the LUN mappings for the vserver that you specify.
-initiator <text>
- Initiator Name (privilege: advanced)-
Selects the LUN mappings for the initiator that you specify.
[-lun-id <integer>]
- Logical Unit Number (privilege: advanced)-
Selects the LUN mappings with a LUN ID that you specify.
[-igroup <text>]
- Igroup Name (privilege: advanced)-
Selects the LUN mappings for the initiator group that you specify.
[-path <path>]
- LUN Path (privilege: advanced)-
Selects the LUN mappings for the LUN path that you specify.
[-node <nodename>]
- LUN Node (privilege: advanced)-
Selects the LUN mappings for the LUNs which are being hosted on the node that you specify.
[-reporting-nodes <nodename>,…]
- Reporting Nodes (privilege: advanced)-
Selects the LUN mappings for the LUNs which have reporting nodes that you specify.
[-vserver-uuid <UUID>]
- Vserver UUID (privilege: advanced)-
Selects the LUN mappings for the Vserver UUID that you specify.
[-igroup-uuid <UUID>]
- Igroup UUID (privilege: advanced)-
Selects the LUN mappings for the initiator group UUID that you specify.
[-lun-uuid <UUID>]
- LUN UUID (privilege: advanced)-
Selects the LUN mappings for the LUN UUID that you specify.
The following example displays the LUN mappings for initiator 20:10:0a:50:00:01:01:01
in Vserver vs1
cluster1::> lun mapping show-initiator -vserver vs1 -initiator 20:10:0a:50:00:01:01:01 Vserver Initiator LUN ID Path IGroup ------- --------- ------ ----------------------------------- ---------------- vs1 20:10:0a:50:00:01:01:01 0 /vol/igroup_1_1_vol/lun1 igroup_1 2 /vol/igroup_1_1_vol/lun3 igroup_1 3 /vol/igroup_1_2_vol/lun1 igroup_1 5 /vol/igroup_1_2_vol/lun3 igroup_1 6 /vol/igroup_1_3_vol/lun1 igroup_1 8 /vol/igroup_1_3_vol/lun3 igroup_1 9 /vol/igroup_1_4_vol/lun1 igroup_1 11 /vol/igroup_1_4_vol/lun3 igroup_1 12 /vol/igroup_2_1_vol/lun1 igroup_2 14 /vol/igroup_2_1_vol/lun3 igroup_2 15 /vol/igroup_2_2_vol/lun1 igroup_2 17 /vol/igroup_2_2_vol/lun3 igroup_2 18 /vol/igroup_2_3_vol/lun1 igroup_2 20 /vol/igroup_2_3_vol/lun3 igroup_2 21 /vol/igroup_2_4_vol/lun1 igroup_2 23 /vol/igroup_2_4_vol/lun3 igroup_2 16 entries were displayed.
