vserver unlock
Unlock Vserver configuration
The vserver unlock
command revokes the administrative lock on the Vserver configuration. When a Vserver is unlocked, changes to the configuration are permitted. The unlock operation fails if the Vserver is not locked by the administrator or if it is locked by internal applications. If the Vserver fails to unlock due to an error condition, you can use the -force option.
-vserver <vserver>
- Vserver (privilege: advanced)-
The name of the Vserver that has to be unlocked.
[-force <true>]
- Force Unlock (privilege: advanced)-
This option is specified to unlock the Vserver when the Vserver fails to unlock due to an error condition.
The following example illustrates how to unlock the Vserver named vs123.example.com, forcefully
cluster1::> vserver unlock -vserver vs1.example.com -force true
