job initstate show
Display init state for job managers
The job initstate show command displays information about the initialization states of job-manager processes.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node (privilege: advanced)-
Selects the nodes that match this parameter value.
[-process <process_name>]- Process Name (privilege: advanced)-
[-initialized {true|false}]- Initialized? (privilege: advanced)-
Selects the nodes that match this parameter value (
truemeans initialized;falsemeans not initialized). [-cache-root <text>]- Cache Root (privilege: advanced)-
[-siteid <UUID>]- Site ID (privilege: advanced)-
[-hp-threads <integer>]- High Priority Threads (privilege: advanced)-
Selects the nodes that have the number of high-priority threads you specify.
[-mp-threads <integer>]- Medium Priority Threads (privilege: advanced)-
Selects the nodes that have the number of medium-priority threads you specify.
[-lp-threads <integer>]- Low Priority Threads (privilege: advanced)-
Selects the nodes that have the number of low-priority threads you specify.
[-tx-interval <integer>]- Transaction Interval (privilege: advanced)-
Selects the nodes that have the number of seconds you specify as their transaction interval.
[-initmsg <text>]- Initialization Message (privilege: advanced)-
[-thread-initmsg <text>]- Thread Initialization Message (privilege: advanced)-
Selects the nodes that match this parameter value. The thread initialization message contains information about thread status. If there is no information to communicate, this message is empty.
[-recovery-enabled {true|false}]- Job Failover Enabled? (privilege: advanced)-
truemeans enabled,falsemeans not enabled). [-ex-threads <integer>]- Exclusive Priority Threads (privilege: advanced)-
The following example shows how to display general job-manager initialization-state information for a cluster.
cluster1::*> job initstate show
HP MP LP EX
Node Process Init? Thr Thr Thr Thr TX Int Failover?
node1 mgwd true 2 3 5 8 300 true
node2 mgwd true 2 3 5 8 300 true
2 entries were displayed.
The following example shows how to display detailed job-manager initialization-state information for a node named node0 .
cluster1::*> job initstate show -instance -node node0
Node: node0
Process Name: mgwd
Initialized?: true
Cache Root: /mroot/jm_cache
Site ID: 824e8f7d-f49-1d9-84af-00423b7352
High Priority Threads: 2
Medium Priority Threads: 3
Low Priority Threads: 5
Transaction Interval: 300
Initialization Message: Initialized
Are Threads Running?: -
Job Failover Enabled?: true
Exclusive Priority Threads: 8
