ONTAP commands
job initstate show
Display init state for job managers
The job initstate show command displays information about the initialization states of job-manager processes.
[-fields <fieldname>,…​]
| [-instance ] (privilege: advanced) }
[-node {<nodename>|local}] - Node (privilege: advanced)
Selects the nodes that match this parameter value.
[-process <process_name>] - Process Name (privilege: advanced)
[-initialized {true|false}] - Initialized? (privilege: advanced)
Selects the nodes that match this parameter value (true means initialized; false means not initialized).
[-cache-root <text>] - Cache Root (privilege: advanced)
[-siteid <UUID>] - Site ID (privilege: advanced)
[-hp-threads <integer>] - High Priority Threads (privilege: advanced)
Selects the nodes that have the number of high-priority threads you specify.
[-mp-threads <integer>] - Medium Priority Threads (privilege: advanced)
Selects the nodes that have the number of medium-priority threads you specify.
[-lp-threads <integer>] - Low Priority Threads (privilege: advanced)
Selects the nodes that have the number of low-priority threads you specify.
[-tx-interval <integer>] - Transaction Interval (privilege: advanced)
Selects the nodes that have the number of seconds you specify as their transaction interval.
[-initmsg <text>] - Initialization Message (privilege: advanced)
[-thread-initmsg <text>] - Thread Initialization Message (privilege: advanced)
Selects the nodes that match this parameter value. The thread initialization message contains information about thread status. If there is no information to communicate, this message is empty.
[-recovery-enabled {true|false}] - Job Failover Enabled? (privilege: advanced)
Selects the nodes that match this parameter value (true means enabled, false means not enabled).
[-ex-threads <integer>] - Exclusive Priority Threads (privilege: advanced)
The following example shows how to display general job-manager initialization-state information for a cluster.
cluster1::*> job initstate show
                                    HP   MP   LP   EX
Node              Process     Init? Thr  Thr  Thr  Thr  TX Int Failover?
node1             mgwd        true  2    3    5    8    300    true
node2             mgwd        true  2    3    5    8    300    true
2 entries were displayed.
The following example shows how to display detailed job-manager initialization-state information for a node named node0 .
cluster1::*> job initstate show -instance -node node0
                      Node: node0
              Process Name: mgwd
              Initialized?: true
                Cache Root: /mroot/jm_cache
                   Site ID: 824e8f7d-f49-1d9-84af-00423b7352
     High Priority Threads: 2
   Medium Priority Threads: 3
      Low Priority Threads: 5
      Transaction Interval: 300
    Initialization Message: Initialized
      Are Threads Running?: -
     Job Failover Enabled?: true
Exclusive Priority Threads: 8
