network interface failover-groups rename
Rename a logical interface failover Group
The network interface failover-groups rename
command enables you to rename an existing logical interface failover group.
-vserver <vserver>
- Vserver Name-
Use this parameter to specify the name of the Vservers from which this failover group is accessible.
-failover-group <text>
- Failover Group Name-
Use this parameter to specify the failover group that you want to rename.
-new-failover-group-name <text>
- New name-
Use this parameter to specify the new name of the failover group.
This example shows the failover group "clusterwide" being renamed "clyde".
cluster1::> network interface failover-group rename -failover -vserver vs1 -failover-group clusterwide -new-failover-group-name clyde
