      vserver cifs branchcache delete
Stop and remove the CIFS BranchCache service
The vserver cifs branchcache delete command stops and removes the Vserver BranchCache configuration.
- -vserver <vserver name>- Vserver
This parameter specifies the CIFS-enabled Vserver whose BranchCache configuration you want to remove.
- -flush-hashes {true|false}- Delete Existing Hashes
This parameter specifies whether to keep or delete all existing hashes after deleting the BranchCache service.
The following example stops and removes the BranchCache service on the Vserver vs1. It also deletes all existing hashes.
cluster1::> vserver cifs branchcache delete -flush-hashes true -vserver vs1
 PDFs
PDFs
