statistics catalog counter show
Display the list of counters in an object
This command displays the names and descriptions of counters. The displayed data is either node-specific or cluster-wide, depending on the objects specified.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-describe ]
(privilege: advanced) } -
Displays detailed information about each counter, including privilege level, label, and whether the counter is a key counter.
-object <text>
- Object (privilege: advanced)-
Selects the object for which you want to display the list of counters. This parameter is required. To view a list of valid object names, type
or statistics catalog object show .-object
`?` [-counter <text>]
- Counter (privilege: advanced)-
Selects the counters that match this parameter value. If you do not specify this parameter, the command displays details for all counters.
[-filter <text>]
- Filter Data (privilege: advanced)-
Selects the counters that match this parameter value. For example, to display counters from node1, specify
-filter "node_name=node1"
. [-label <text>,…]
- Labels for Array Counters (privilege: advanced)-
Selects the counters that match this parameter value. A label is the name of the bucket to which an array counter belongs.
[-description <text>]
- Description (privilege: advanced)-
[-privilege <text>]
- Privilegel Level (privilege: advanced)-
[-is-key-counter {true|false}]
- Is Key Counter (privilege: advanced)-
Selects the counters that are key counters (true) or are not key counters (false). A key counter is a counter that uniquely identifies an instance across the cluster. The default setting is false. For example, "vserver_name" and "node_name" are key counters because they identify the specific Vserver or node to which the instance belongs.
[-is-deprecated {true|false}]
- Is Counter Deprecated (privilege: advanced)-
Selects the counters that are deprecated (true) or are not deprecated (false).
[-replaced-by <text>]
- Replaced By Counter If Deprecated (privilege: advanced)-
Selects all deprecated counters that are replaced by the counter provided to this parameter.
The following example displays the list of counters in the processor object.
cluster1::> statistics catalog counter show -object processor Object: processor Counter Description --------------------------- ---------------------------------------------- instance_name Instance Name instance_uuid Instance UUID node_name System node name node_uuid System node id process_name Ontap process that provided this instance processor_busy Percentage of elapsed time that the processor is executing non-idle processes processor_elapsed_time Wall-clock time since boot used for calculating processor utilization sk_switches Number of sk switches per second 8 entries were displayed.
