statistics catalog counter show
Display the list of counters in an object
This command displays the names and descriptions of counters. The displayed data is either node-specific or cluster-wide, depending on the objects specified.
[-fields <fieldname>,…]-
If you specify the
[-describe ](privilege: advanced) } -
Displays detailed information about each counter, including privilege level, label, and whether the counter is a key counter.
-object <text>- Object (privilege: advanced)-
Selects the object for which you want to display the list of counters. This parameter is required. To view a list of valid object names, type
statistics catalog counter show?`` or statistics catalog object show .-object [-counter <text>]- Counter (privilege: advanced)-
Selects the counters that match this parameter value. If you do not specify this parameter, the command displays details for all counters.
[-filter <text>]- Filter Data (privilege: advanced)-
Selects the counters that match this parameter value. For example, to display counters from node1, specify
-filter "node_name=node1". [-label <text>,…]- Labels for Array Counters (privilege: advanced)-
Selects the counters that match this parameter value. A label is the name of the bucket to which an array counter belongs.
[-description <text>]- Description (privilege: advanced)-
[-privilege <text>]- Privilegel Level (privilege: advanced)-
[-is-key-counter {true|false}]- Is Key Counter (privilege: advanced)-
Selects the counters that are key counters (true) or are not key counters (false). A key counter is a counter that uniquely identifies an instance across the cluster. The default setting is false. For example, "vserver_name" and "node_name" are key counters because they identify the specific Vserver or node to which the instance belongs.
[-is-deprecated {true|false}]- Is Counter Deprecated (privilege: advanced)-
Selects the counters that are deprecated (true) or are not deprecated (false).
[-replaced-by <text>]- Replaced By Counter If Deprecated (privilege: advanced)-
Selects all deprecated counters that are replaced by the counter provided to this parameter.
The following example displays the list of counters in the processor object.
cluster1::> statistics catalog counter show -object processor
Object: processor
Counter Description
instance_name Instance Name
instance_uuid Instance UUID
node_name System node name
node_uuid System node id
process_name Ontap process that provided this instance
processor_busy Percentage of elapsed time that the processor
is executing non-idle processes
processor_elapsed_time Wall-clock time since boot used for
calculating processor utilization
sk_switches Number of sk switches per second
8 entries were displayed.
