lun igroup rename
Rename an existing initiator group
This command renames an existing initiator group. When you rename an initiator group, this action does not affect access to the LUNs mapped to the initiator group you want to rename.
An initiator group name is a case-sensitive name and must meet the following requirements:
Must contain one to 96 characters. Spaces are not allowed.
Can contain the letters A through Z, a through z, numbers 0 through 9, hyphen (-), underscore (_), colon (:), and period (.).
Must start with a letter or number.
-vserver <Vserver Name>
- Vserver Name-
Specifies the Vserver.
-igroup <text>
- Igroup Name-
Specifies the initiator group you want to rename.
-new-name <text>
- New Igroup Name-
Specifies the new name of the initiator group.
cluster1::> lun igroup rename -vserver vs1 -igroup ig1 -new-name ignew1
Renames an initiator group from ig1 to ignew1 on Vserver vs1.
