ONTAP commands
system node hardware unified-connect show
Displays information about Fibre Channel and converged networking adapters
This command manages Fibre Channel and converged networking adapters used by the storage subsystem. Use the command to show the current mode and FC-4 type of adapters or the capabilities of adapters.
{ [-fields <fieldname>,…​]
| [-capability ]
If this parameter is specified, the command displays the capabilities of the adapters.
| [-instance ] }
[-node {<nodename>|local}] - Node
If this parameter is specified, the command displays information about Fibre Channel and converged networking adapters on the specified node.
[-adapter <text>] - Adapter
If this parameter is specified, the command displays information about the specified adapter.
[-current-mode {fc|cna}] - Current Mode
If this parameter is specified, the command displays adapters configured to the specified mode.
[-current-type {initiator|target|fcvi}] - Current Type
If this parameter is specified, the command displays adapters configured to the specified FC-4 type.
[-pending-mode {fc|cna}] - Pending Mode
If this parameter is specified, the command displays adapters configured to the specified mode on the next reboot.
[-pending-type {initiator|target|fcvi}] - Pending Type
If this parameter is specified, the command displays adapters configured to the specified FC-4 on the next reboot.
[-status-admin <text>] - Administrative Status
If this parameter is specified, the command displays adapters with the specified status.
[-supported-modes {fc|cna}] - Supported Modes
The list of modes that the adapter supports.
[-supported-fc-types {initiator|target|fcvi}] - Supported FC Types
The list of FC-4 types the adapter supports when configured into fc mode.
[-supported-cna-types {initiator|target|fcvi}] - Supported CNA Types
The list of FC-4 types the adapter supports when configured into cna mode.
The following example displays information about all Fibre Channel and converged networking adapters in the cluster:
cluster1::> system node hardware unified-connect show
                       Current  Current    Pending  Pending    Admin
Node          Adapter  Mode     Type       Mode     Type       Status
node1         0c       fc       initiator  -        -          online
node1         0d       fc       initiator  -        -          online
node1         3a       fc       target     -        -          online
node1         3b       fc       target     -        -          online
node1         4a       cna      target     -        -          online
node1         4b       cna      target     -        -          online
node1         6a       fc       target     -        -          online
node1         6b       fc       target     -        -          online
node2         0c       fc       initiator  -        -          online
node2         0d       fc       initiator  -        -          online
node2         3a       fc       target     -        -          online
node2         3b       fc       target     -        -          online
node2         4a       cna      target     -        -          online
node2         4b       cna      target     -        -          online
node2         6a       cna      target     -        -          online
node2         6b       cna      target     -        -          online
16 entries were displayed.
