protection-type show
Display the supported protection types and available RPOs
This command displays the protection types available for application provisioning.
- { [-fields <fieldname>,…]
Specifies fields that you want included in the output. You can use -fields ?to display the available fields.
- | [-instance ]}
Specifies the display of all available fields for each selected protection type.
- [-vserver <vserver name>]- Vserver (privilege: advanced)
Selects the protection types of Vservers that match the parameter value.
- [-protection-type {local|remote}]- Protection Type (privilege: advanced)
Selects the protection types that match the parameter value.
- [-rpo-list <text>,…]- List of available RPOs (privilege: advanced)
Selects the protection types whose list of available RPOs matches the parameter value.
- [-rpo-list-description <text>,…]- List of descriptions of available RPOs (privilege: advanced)
Selects the protection types whose list of description of available RPOs matches the parameter value.
- [-description <text>]- Description of Protection Type (privilege: advanced)
Selects the protection types with a description that matches the parameter value.
The following example displays the protection types and the associated available RPOs for all Vservers in the cluster.
cluster1::*> protection-type show
Vserver Protection Type RPO List
vs1
        local           hourly, none
  remote          none
vs2
        local           hourly, none
  remote          none, zero
 PDFs
PDFs
