ONTAP commands
protection-type show
Display the supported protection types and available RPOs
This command displays the protection types available for application provisioning.
[-fields <fieldname>,…​]
Specifies fields that you want included in the output. You can use -fields ? to display the available fields.
| [-instance ] (privilege: advanced) }
Specifies the display of all available fields for each selected protection type.
[-vserver <vserver name>] - Vserver (privilege: advanced)
Selects the protection types of Vservers that match the parameter value.
[-protection-type {local|remote}] - Protection Type (privilege: advanced)
Selects the protection types that match the parameter value.
[-rpo-list <text>,…​] - List of available RPOs (privilege: advanced)
Selects the protection types whose list of available RPOs matches the parameter value.
[-rpo-list-description <text>,…​] - List of descriptions of available RPOs (privilege: advanced)
Selects the protection types whose list of description of available RPOs matches the parameter value.
[-description <text>] - Description of Protection Type (privilege: advanced)
Selects the protection types with a description that matches the parameter value.
The following example displays the protection types and the associated available RPOs for all Vservers in the cluster.
cluster1::*> protection-type show
Vserver Protection Type RPO List
vs1
        local           hourly, none
  remote          none
vs2
        local           hourly, none
  remote          none, zero
