security key-manager external aws rekey-internal
Rekey an internal key of the Vserver
This command updates the internal Vserver key hierarchy by rekeying the top-level internal key encryption key (KEK). Upon successful completion of the command, all keys in the Vserver key hierarchy will be protected by the new top-level KEK.
-vserver <Vserver Name>
- Vserver (privilege: advanced)-
This parameter specifies the Vserver for which ONTAP should rekey the top-level KEK
The following command rekeys the top-level KEK for data Vserver vs1.
cluster-1::> security key-manager external aws rekey-internal -vserver vs1
