event role-config delete
Delete role-based event configuration
The event role-config delete
command deletes the EMS role-based configuration of an access control role.
-access-control-role <text>
- Access Control Role (privilege: advanced)-
Use this mandatory parameter to specify the access control role for which the EMS role-based configuration needs to be deleted.
The following example shows the deletion of a role-based event configuration:
cluster1::> event role-config show Access Control Role Filter Name Limit Access to Global Configs ------------------- --------------------- ------------------------------ storage-admin storage-admin-events true cluster1::> event role-config delete -access-control-role storage-admin cluster1::> event role-config show This table is currently empty.
