storage aggregate restrict
Restrict an aggregate
The storage aggregate restrict
command puts an aggregate in restricted state to make data in the aggregate's volumes unavailable to clients. When an aggregate is in restricted state data access is not allowed. However, few operations such as aggregate copy, parity recomputation, scrub and RAID reconstruction are allowed. You can also use this command if you want the aggregate to be the target of an aggregate copy or SnapMirror replication operation.
-aggregate <aggregate name>
- Aggregate-
The name of the aggregate to be restricted.
The following example restricts an aggregate named aggr1:
cluster1::> storage aggregate restrict -aggregate aggr1
