ONTAP commands
volume snapshot policy delete
Delete a snapshot policy
The volume snapshot policy delete command deletes a Snapshot policy.
-vserver <vserver name> - Vserver Name
This specifies the Vserver on which the Snapshot policy is to be deleted.
-policy <snapshot policy> - Snapshot Policy Name
This specifies the Snapshot policy that is to be deleted.
The following example deletes a Snapshot policy named snappolicy_hourly on Vserver vs0:
cluster1::> volume snapshot policy delete -vserver vs0 -policy snappolicy_hourly
