ONTAP commands
storage iscsi-initiator show
Display the iSCSI targets
The storage iscsi-initiator show displays the list of iSCSI targets configured for each ONTAP node in the cluster. This command is only supported on high-availability shared-nothing virtualized platforms.
[-fields <fieldname>,…​]
| [-instance ] (privilege: advanced) }
[-node {<nodename>|local}] - Node (privilege: advanced)
Represents the name of the ONTAP node for which information is to be displayed. If this parameter is not specified, the command displays information about all nodes in the cluster.
[-target-type {external|mailbox|partner|partner2|dr_auxiliary|dr_partner}] - Target Type (privilege: advanced)
Selects targets with the specified target type.
[-label <text>] - User Defined Identifier (privilege: advanced)
Selects targets with the specified label.
[-target-portal <text>] - Target Portal (privilege: advanced)
Selects targets with the specified portal.
[-target-name <text>] - iSCSI Name (privilege: advanced)
Selects targets with the specified target name.
[-status-admin {down|up}] - Administrative Status (privilege: advanced)
Selects targets with the specified administrative status.
[-status-oper {down|up}] - Operational Status (privilege: advanced)
Selects targets with the specified operational status.
[-failure-reason <text>] - Failure Reason (privilege: advanced)
Selects targets with the specified failure reason.
The following example displays the list of iSCSI targets for each node in the cluster.
cluster1::*> storage iscsi-initiator show
        Status
Node Type Label    Target Portal      Target Name                      Admin/Op
node1
     mailbox
          mediator 10.235.14.141      iqn.2012-05.local:mailbox.group.1  up/up
     partner
          partner  10.63.7.205:65200  iqn.2012-06.com.bsdctl:target0     up/up
node2
     mailbox
     partner
          partner  10.63.7.201:65200  iqn.2012-06.com.bsdctl:target0     up/up
4 entries were displayed.
