Commands for managing aggregates
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
You use the storage aggregate
command to manage your aggregates.
If you want to… | Use this command… |
Display the size of the cache for all Flash Pool aggregates |
Display disk information and status for an aggregate |
Display spare disks by node |
Display the root aggregates in the cluster |
Display basic information and status for aggregates |
Display the type of storage used in an aggregate |
Bring an aggregate online |
Delete an aggregate |
Put an aggregate into the restricted state |
Rename an aggregate |
Take an aggregate offline |
Change the RAID type for an aggregate |
