Create a relationship from an Element source to an ONTAP destination
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
The relationship between the source volume in primary storage and the destination volume in secondary storage is called a data protection relationship. You can use the snapmirror create
command to create a data protection relationship from an Element source to an ONTAP destination, or from an ONTAP source to an Element destination.
You can use SnapMirror to replicate Snapshot copies of an Element volume to an ONTAP destination system. In the event of a disaster at the Element site, you can serve data to clients from the ONTAP system, then reactivate the Element source volume when service is restored.
The Element node containing the volume to be replicated must have been made accessible to ONTAP.
The Element volume must have been enabled for SnapMirror replication.
If you are using the “mirror-vault” policy type, a SnapMirror label must have been configured for the Element Snapshot copies to be replicated.
You can perform this task in the Element software web UI only. For more information, see the Element documentation.
You must specify the Element source path in the form hostip:/lun/name
, where “lun” is the actual string “lun” and name
is the name of the Element volume.
An Element volume is roughly equivalent to an ONTAP LUN. SnapMirror creates a LUN with the name of the Element volume when a data protection relationship between Element software and ONTAP is initialized. SnapMirror replicates data to an existing LUN if the LUN meets the requirements for replicating from Element software to ONTAP.
Replication rules are as follows:
An ONTAP volume can contain data from one Element volume only.
You cannot replicate data from an ONTAP volume to multiple Element volumes.
In ONTAP 9.3 and earlier, a destination volume can contain up to 251 Snapshot copies. In ONTAP 9.4 and later, a destination volume can contain up to 1019 Snapshot copies.
From the destination cluster, create a replication relationship from an Element source to an ONTAP destination:
snapmirror create -source-path hostip:/lun/name -destination-path SVM:volume|cluster://SVM/volume -type XDP -schedule schedule -policy policy
For complete command syntax, see the man page.
The following example creates a SnapMirror DR relationship using the default
MirrorLatest
policy:cluster_dst::> snapmirror create -source-path 10.0.0.11:/lun/0005 -destination-path svm_backup:volA_dst -type XDP -schedule my_daily -policy MirrorLatest
The following example creates a unified replication relationship using the default
MirrorAndVault
policy:cluster_dst:> snapmirror create -source-path 10.0.0.11:/lun/0005 -destination-path svm_backup:volA_dst -type XDP -schedule my_daily -policy MirrorAndVault
Unified7year
policy:cluster_dst::> snapmirror create -source-path 10.0.0.11:/lun/0005 -destination-path svm_backup:volA_dst -type XDP -schedule my_daily -policy Unified7year
The following example creates a unified replication relationship using the custom
my_unified
policy:cluster_dst::> snapmirror create -source-path 10.0.0.11:/lun/0005 -destination-path svm_backup:volA_dst -type XDP -schedule my_daily -policy my_unified
Use the snapmirror show
command to verify that the SnapMirror relationship was created. For complete command syntax, see the man page.
