Control and monitor I/O performance to LUNs by using Storage QoS
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
You can control input/output (I/O) performance to LUNs by assigning LUNs to Storage QoS policy groups. You might control I/O performance to ensure that workloads achieve specific performance objectives or to throttle a workload that negatively impacts other workloads.
Policy groups enforce a maximum throughput limit (for example, 100 MB/s). You can create a policy group without specifying a maximum throughput, which enables you to monitor performance before you control the workload.
You can also assign storage virtual machines (SVMs) with FlexVol volumes and LUNs to policy groups.
Note the following requirements about assigning a LUN to a policy group:
The LUN must be contained by the SVM to which the policy group belongs.
You specify the SVM when you create the policy group.
If you assign a LUN to a policy group, then you cannot assign the LUN's containing volume or SVM to a policy group.
For more information about how to use Storage QoS, see the System administration reference.
Use the
qos policy-group create
command to create a policy group. -
Use the
lun create
command or thelun modify
command with the-qos-policy-group
parameter to assign a LUN to a policy group. -
Use the
qos statistics
commands to view performance data. -
If necessary, use the
qos policy-group modify
command to adjust the policy group's maximum throughput limit.
