Create a portset and bind to an igroup
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
In addition to using Selective LUN Map (SLM), you can create a portset and bind the portset to an igroup to further limit which LIFs can be used by an initiator to access a LUN.
If you do not bind a portset to an igroup, then all of the initiators in the igroup can access mapped LUNs through all of the LIFs on the node owning the LUN and the owning node's HA partner.
You must have at least one LIF and one igroup.
Unless you are using interface groups, two LIFs are recommended for redundancy for both iSCSI and FC. Only one LIF is recommended for interface groups.
It is advantageous to use portsets with SLM when you have more than two LIFs on a node and you want to restrict a certain initiator to a subset of LIFs. Without portsets, all targets on the node will be accessible by all of the initiators with access to the LUN through the node owning the LUN and the owning node's HA partner.
Beginning with ONTAP 9.10.1, you can use System Manager to create portsets and bind them to igroups.
If you need to create a portset and bind it to an igroup in an ONTAP release earlier than 9.10.1 you must use the ONTAP CLI procedure.
In System Manager, click Network > Overview > Portsets, and click Add.
Enter the information for the new portset and click Add.
Click Hosts > SAN Initiator Groups.
To bind the portset to a new igroup, click Add.
To bind the portset to an existing igroup, select the igroup, click , and then click Edit Initiator Group.
Create a port set containing the appropriate LIFs:
portset create -vserver vserver_name -portset portset_name -protocol protocol -port-name port_name
If you are using FC, specify the
protocol
parameter asfcp
. If you are using iSCSI, specify theprotocol
parameter asiscsi
Bind the igroup to the port set:
lun igroup bind -vserver vserver_name -igroup igroup_name -portset portset_name
Verify that your port sets and LIFs are correct:
portset show -vserver vserver_name
Vserver Portset Protocol Port Names Igroups --------- --------- -------- ------------- -------- vs3 portset0 iscsi lif0,lif1 igroup1
