Access the system console of a node
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
- Data protection and disaster recovery
Creating your file...
If a node is hanging at the boot menu or the boot environment prompt, you can access it only through the system console (also called the serial console). You can access the system console of a node from an SSH connection to the node's SP or to the cluster.
Both the SP and ONTAP offer commands that enable you to access the system console. However, from the SP, you can access only the system console of its own node. From the cluster, you can access the system console of any node in the cluster.
Access the system console of a node:
If you are in the… Enter this command… SP CLI of the node
system console
ONTAP CLI
system node run-console
Log in to the system console when you are prompted to do so.
To exit the system console, press Ctrl-D.
The following example shows the result of entering the system console
command at the “SP node2” prompt. The system console indicates that node2 is hanging at the boot environment prompt. The boot_ontap
command is entered at the console to boot the node to ONTAP. Ctrl-D is then pressed to exit the console and return to the SP.
SP node2> system console Type Ctrl-D to exit. LOADER> LOADER> boot_ontap ... ******************************* * * * Press Ctrl-C for Boot Menu. * * * ******************************* ...
(Ctrl-D is pressed to exit the system console.)
Connection to 123.12.123.12 closed. SP node2>
The following example shows the result of entering the system node run-console
command from ONTAP to access the system console of node2, which is hanging at the boot environment prompt. The boot_ontap
command is entered at the console to boot node2 to ONTAP. Ctrl-D is then pressed to exit the console and return to ONTAP.
cluster1::> system node run-console -node node2 Pressing Ctrl-D will end this session and any further sessions you might open on top of this session. Type Ctrl-D to exit. LOADER> LOADER> boot_ontap ... ******************************* * * * Press Ctrl-C for Boot Menu. * * * ******************************* ...
Connection to 123.12.123.12 closed. cluster1::>
