Commands for managing configuration backup files
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
- Data protection and disaster recovery
Creating your file...
You use the system configuration backup
commands to manage cluster and node configuration backup files.
These commands are available at the advanced privilege level.
If you want to… | Use this command… | ||
Create a new node or cluster configuration backup file |
Copy a configuration backup file from a node to another node in the cluster |
Upload a configuration backup file from a node in the cluster to a remote URL (FTP, HTTP, HTTPS, TFTP, or FTPS) |
When you use HTTPS in the remote URL, use the
Download a configuration backup file from a remote URL to a node in the cluster, and, if specified, validate the digital certificate |
When you use HTTPS in the remote URL, use the |
Rename a configuration backup file on a node in the cluster |
View the node and cluster configuration backup files for one or more nodes in the cluster |
Delete a configuration backup file on a node |
