Restore a cluster configuration from an existing configuration
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
- Data protection and disaster recovery
Creating your file...
To restore a cluster configuration from an existing configuration after a cluster failure, you re-create the cluster using the cluster configuration that you chose and made available to the recovering node, and then rejoin each additional node to the new cluster.
You should only perform this task to recover from a disaster that resulted in the loss of the cluster's configuration.
If you are re-creating the cluster from a configuration backup file, you must contact technical support to resolve any discrepancies between the configuration backup file and the configuration present in the cluster. If you are recovering the cluster from a configuration backup file, any configuration changes made since the backup was taken will be lost. You must resolve any discrepancies between the configuration backup file and the present configuration after recovery. See the Knowledge Base article ONTAP Configuration Backup Resolution Guide for troubleshooting guidance. |
Disable storage failover for each HA pair:
storage failover modify -node node_name -enabled false
You only need to disable storage failover once for each HA pair. When you disable storage failover for a node, storage failover is also disabled on the node's partner.
Halt each node except for the recovering node:
system node halt -node node_name -reason "text"
cluster1::*> system node halt -node node0 -reason "recovering cluster" Warning: Are you sure you want to halt the node? {y|n}: y
Set the privilege level to advanced:
set -privilege advanced
On the recovering node, use the
system configuration recovery cluster recreate
command to re-create the cluster.This example re-creates the cluster using the configuration information stored on the recovering node:
cluster1::*> configuration recovery cluster recreate -from node Warning: This command will destroy your existing cluster. It will rebuild a new single-node cluster consisting of this node and its current configuration. This feature should only be used to recover from a disaster. Do not perform any other recovery operations while this operation is in progress. Do you want to continue? {y|n}: y
A new cluster is created on the recovering node.
If you are re-creating the cluster from a configuration backup file, verify that the cluster recovery is still in progress:
system configuration recovery cluster show
You do not need to verify the cluster recovery state if you are re-creating the cluster from a healthy node.
cluster1::*> system configuration recovery cluster show Recovery Status: in-progress Is Recovery Status Persisted: false
Boot each node that needs to be rejoined to the re-created cluster.
You must reboot the nodes one at a time.
For each node that needs to be joined to the re-created cluster, do the following:
From a healthy node on the re-created cluster, rejoin the target node:
system configuration recovery cluster rejoin -node node_name
This example rejoins the “node2” target node to the re-created cluster:
cluster1::*> system configuration recovery cluster rejoin -node node2 Warning: This command will rejoin node "node2" into the local cluster, potentially overwriting critical cluster configuration files. This command should only be used to recover from a disaster. Do not perform any other recovery operations while this operation is in progress. This command will cause node "node2" to reboot. Do you want to continue? {y|n}: y
The target node reboots and then joins the cluster.
Verify that the target node is healthy and has formed quorum with the rest of the nodes in the cluster:
cluster show -eligibility true
The target node must rejoin the re-created cluster before you can rejoin another node.
cluster1::*> cluster show -eligibility true Node Health Eligibility Epsilon -------------------- ------- ------------ ------------ node0 true true false node1 true true false 2 entries were displayed.
If you re-created the cluster from a configuration backup file, set the recovery status to be complete:
system configuration recovery cluster modify -recovery-status complete
Return to the admin privilege level:
set -privilege admin
If the cluster consists of only two nodes, use the
cluster ha modify
command to reenable cluster HA. -
Use the
command to reenable storage failover for each HA pair.
If the cluster has SnapMirror peer relationships, then you also need to re-create those relationships. For more information, see Data Protection.
