Clone workflow
PDF of this doc site
- Protect Microsoft SQL Server databases
- Protect SAP HANA databases
Creating your file...
Your file is ready
The clone workflow includes planning, performing the clone operation, and monitoring the operation.
You might clone databases for the following reasons:
To test functionality that has to be implemented using the current database structure and content during application development cycles.
To populate data warehouses using data extraction and manipulation tools.
To recover data that was mistakenly deleted or changed.
The following workflow shows the sequence in which you must perform the clone operation:
