SnapCenter Software 5.0
Get started with the REST API
Contributors netapp-nsriram
You can quickly get started using the SnapCenter REST API. Accessing the API provides some perspective before you begin using it with the more complex workflow processes on a live setup.
Hello World
You can run a simple command on your system to get started using the SnapCenter REST API and confirm its availability.
Before you begin
  • Ensure that the Curl utility is available on your system.
  • IP address or host name of the SnapCenter Server
  • User name and password for an account with authority to access the SnapCenter REST API.
Note If your credentials include special characters, you need to format them in a way that is acceptable to Curl based on the shell you are using. For example, you can insert a backslash before each special character or wrap the entire username:password string in single quotes.
Step
At the command line interface, run the following to retrieve the plug-in information:
curl -X GET -u username:password -k "https://<ip_address>/api/hosts?fields=IncludePluginInfo"
Example:
curl -X GET -u admin:password -k "'https://10.225.87.97/api/hosts?fields=IncludePluginInfo"
