Changing the browser session timeout
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
You can control whether Grid Manager and Tenant Manager users are signed out if they are inactive for more than a certain amount of time.
You must be signed in to the Grid Manager using a supported browser.
You must have specific access permissions.
The GUI Inactivity Timeout defaults to 900 seconds (15 minutes). If a user's browser session is not active for this amount of time, the session times out.
As required, you can increase or decrease the timeout period by setting the GUI Inactivity Timeout display option.
If single sign-on (SSO) is enabled and a user's browser session times out, the system behaves as if the user clicked Sign Out manually. The user must reenter their SSO credentials to access StorageGRID again.
User session timeout can also be controlled by the following:
Select Configuration > System Settings > Display Options.
For GUI Inactivity Timeout, enter a timeout period of 60 seconds or more.
Set this field to 0 if you do not want to use this functionality. Users are signed out 16 hours after they sign in, when their authentication tokens expire.
Click Apply Changes.
The new setting does not affect currently signed in users. Users must sign in again or refresh their browsers for the new timeout setting to take effect.
