Changing the provisioning passphrase
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
Use this procedure to change the StorageGRID provisioning passphrase. The passphrase is required for recovery, expansion, and maintenance procedures. The passphrase is also required to download Recovery Package backups that include the grid topology information and encryption keys for the StorageGRID system.
You must be signed in to the Grid Manager using a supported browser.
You must have Maintenance or Root Access permissions.
You must have the current provisioning passphrase.
The provisioning passphrase is required for many installation and maintenance procedures, and for downloading the Recovery Package. The provisioning passphrase is not listed in the Passwords.txt
file. Make sure to document the provisioning passphrase and keep it in a safe and secure location.
Select Configuration > Access Control > Grid Passwords.
Enter your current provisioning passphrase.
Enter the new passsphrase.The passphrase must contain at least 8 and no more than 32 characters. Passphrases are case-sensitive.
Store the new provisioning passphrase in a secure location. It is required for installation, expansion, and maintenance procedures. -
Re-enter the new passphrase, and click Save.
The system displays a green success banner when the provisioning passphrase change is complete. The change should take less than a minute.
Select the Recovery Package page link inside the success banner.
Download the new Recovery Package from the Grid Manager. Select Maintenance > Recovery Package and enter the new provisioning passphrase.
After changing the provisioning passphrase, you must immediately download a new Recovery Package. The Recovery Package file allows you to restore the system if a failure occurs.
