GTSU: Grid Task Submitted
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
This audit message indicates that a grid task has been submitted to the CMN service.
Code | Field | Description |
TSID |
Task ID |
Uniquely identifies a generated grid task and allows the task to be managed over its lifecycle. Note: The Task ID is assigned at the time that a grid task is generated, not the time that it is submitted. It is possible for a given grid task to be submitted multiple times, and in this case the Task ID field is not sufficient to uniquely link the Submitted, Started, and Ended audit messages. |
TTYP |
Task Type |
The type of grid task. |
TVER |
Task Version |
A number indicating the version of the grid task. |
TDSC |
Task Description |
A human-readable description of the grid task. |
VATS |
Valid After Timestamp |
The earliest time (UINT64 microseconds from January 1, 1970 - UNIX time) at which the grid task is valid. |
VBTS |
Valid Before Timestamp |
The latest time (UINT64 microseconds from January 1, 1970 - UNIX time) at which the grid task is valid. |
TSRC |
Source |
The source of the task:
ACTV |
Activation Type |
The type of activation:
RSLT |
Result |
The result of the submission:
