GTSU: Grid Task Submitted
This audit message indicates that a grid task has been submitted to the CMN service.
| Code | Field | Description |
TSID  |
Task ID  |
Uniquely identifies a generated grid task and allows the task to be managed over its lifecycle. Note: The Task ID is assigned at the time that a grid task is generated, not the time that it is submitted. It is possible for a given grid task to be submitted multiple times, and in this case the Task ID field is not sufficient to uniquely link the Submitted, Started, and Ended audit messages.  |
TTYP  |
Task Type  |
The type of grid task.  |
TVER  |
Task Version  |
A number indicating the version of the grid task.  |
TDSC  |
Task Description  |
A human-readable description of the grid task.  |
VATS  |
Valid After Timestamp  |
The earliest time (UINT64 microseconds from January 1, 1970 - UNIX time) at which the grid task is valid.  |
VBTS  |
Valid Before Timestamp  |
The latest time (UINT64 microseconds from January 1, 1970 - UNIX time) at which the grid task is valid.  |
TSRC  |
Source  |
The source of the task:
ACTV  |
Activation Type  |
The type of activation:
RSLT  |
Result  |
The result of the submission:
