Using the audit-explain tool
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
You can use the audit-explain
tool to translate the audit messages in the audit log into an easy-to-read format.
You must have specific access permissions.
You must have the
Passwords.txt
file. -
You must know the IP address of the primary Admin Node.
The audit-explain
tool, available on the primary Admin Node, provides simplified summaries of the audit messages in an audit log.
The audit-explain tool is primarily intended for use by technical support during troubleshooting operations. Processing audit-explain queries can consume a large amount of CPU power, which might impact StorageGRID operations.
This example shows typical output from the audit-explain
tool. These four SPUT audit messages were generated when the S3 tenant with account ID 92484777680322627870 used S3 PUT requests to create a bucket named "bucket1" and add three objects to that bucket.
SPUT S3 PUT bucket bucket1 account:92484777680322627870 usec:124673 SPUT S3 PUT object bucket1/part1.txt tenant:92484777680322627870 cbid:9DCB157394F99FE5 usec:101485 SPUT S3 PUT object bucket1/part2.txt tenant:92484777680322627870 cbid:3CFBB07AB3D32CA9 usec:102804 SPUT S3 PUT object bucket1/part3.txt tenant:92484777680322627870 cbid:5373D73831ECC743 usec:93874
The audit-explain
tool can process plain or compressed audit logs. For example:
audit-explain audit.log
audit-explain 2019-08-12.txt.gz
The audit-explain
tool can also process multiple files at once. For example:
audit-explain audit.log 2019-08-12.txt.gz 2019-08-13.txt.gz
audit-explain /var/local/audit/export/*
Finally, the audit-explain
tool can accept input from a pipe, which allows you to filter and preprocess the input using the grep
command or other means. For example:
grep SPUT audit.log | audit-explain
grep bucket-name audit.log | audit-explain
Since audit logs can be very large and slow to parse, you can save time by filtering parts that you want to look at and running audit-explain
on the parts, instead of the entire file.
The audit-explain tool does not accept compressed files as piped input. To process compressed files, provide their file names as command-line arguments, or use the zcat tool to decompress the files first. For example:
zcat audit.log.gz | audit-explain
Use the help (-h)
option to see the available options. For example:
$ audit-explain -h
Log in to the primary Admin Node:
Enter the following command:
ssh admin@primary_Admin_Node_IP
Enter the password listed in the
Passwords.txt
file.
Enter the following command, where
/var/local/audit/export/audit.log
represents the name and the location of the file or files you want to analyze:$ audit-explain /var/local/audit/export/audit.log
The
audit-explain
tool prints human-readable interpretations of all messages in the specified file or files.To reduce line lengths and to aid readability, timestamps are not shown by default. If you want to see the timestamps, use the timestamp ( -t
) option.
