SPUT: S3 PUT
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
When an S3 client issues a PUT transaction, a request is made to create a new object or bucket. This message is issued by the server if the transaction is successful.
Code | Field | Description |
CBID |
Content Block Identifier |
The unique identifier of the content block requested. If the CBID is unknown, this field is set to 0. Operations on buckets do not include this field. |
CMPS |
Compliance Settings |
The compliance settings used when creating the bucket, if present in the PUT Bucket request (truncated to the first 1024 characters) |
CNCH |
Consistency Control Header |
The value of the Consistency-Control HTTP request header, if present in the request. |
CNID |
Connection Identifier |
The unique system identifier for the TCP/IP connection. |
CSIZ |
Content Size |
The size of the retrieved object in bytes. Operations on buckets do not include this field. |
HTRH |
HTTP Request Header |
List of logged HTTP request header names and values as selected during configuration. Note: |
LKEN |
Object Lock Enabled |
Value of the request header |
LKLH |
Object Lock Legal Hold |
LKMD |
Object Lock Retention Mode |
LKRU |
Object Lock Retain Until Date |
MTME |
Last Modified Time |
The Unix timestamp, in microseconds, indicating when the object was last modified. |
RSLT |
Result Code |
Result of the PUT transaction. Result is always: SUCS: Successful |
S3AI |
S3 tenant account ID (request sender) |
The tenant account ID of the user who sent the request. An empty value indicates anonymous access. |
S3AK |
S3 Access Key ID (request sender) |
The hashed S3 access key ID for the user that sent the request. An empty value indicates anonymous access. |
S3BK |
S3 Bucket |
The S3 bucket name. |
S3KY |
S3KY |
The S3 key name, not including the bucket name. Operations on buckets do not include this field. |
S3SR |
S3 Subresource |
The bucket or object subresource being operated on, if applicable. |
SACC |
S3 tenant account name (request sender) |
The name of the tenant account for the user who sent the request. Empty for anonymous requests. |
SAIP |
IP address (request sender) |
The IP address of the client application that made the request. |
SBAC |
S3 tenant account name (bucket owner) |
The tenant account name for the bucket owner. Used to identify cross-account or anonymous access. |
SBAI |
S3 tenant account ID (bucket owner) |
The tenant account ID of the owner of the target bucket. Used to identify cross-account or anonymous access. |
SRCF |
Subresource Configuration |
The new subresource configuration (truncated to the first 1024 characters). |
SUSR |
S3 User URN (request sender) |
The tenant account ID and the user name of the user making the request. The user can either be a local user or an LDAP user. For example: Empty for anonymous requests. |
TIME |
Time |
Total processing time for the request in microseconds. |
TLIP |
Trusted Load Balancer IP Address |
If the request was routed by a trusted Layer 7 load balancer, the IP address of the load balancer. |
ULID |
Upload ID |
Included only in SPUT messages for Complete Multipart Upload operations. Indicates that all parts have been uploaded and assembled. |
UUID |
Universally Unique Identifier |
The identifier of the object within the StorageGRID system. |
VSID |
Version ID |
The version ID of a new object created in a versioned bucket. Operations on buckets and objects in unversioned buckets do not include this field. |
VSST |
Versioning State |
The new versioning state of a bucket. Two states are used: "enabled" or "suspended." Operations on objects do not include this field. |
