Configuring the Docker storage volume
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
Your file is ready
Before installing Docker, you might need to format the Docker storage volume and mount it on /var/lib/docker
About this task
You can skip these steps if you plan to use local storage for the Docker storage volume and have sufficient space available on the host partition containing /var/lib
Steps
Create a file system on the Docker storage volume:
sudo mkfs.ext4 docker-storage-volume-device
Mount the Docker storage volume:
sudo mkdir -p /var/lib/docker sudo mount docker-storage-volume-device /var/lib/docker
Add an entry for docker-storage-volume-device to /etc/fstab.
This step ensures that the storage volume will remount automatically after host reboots.
