Obtaining the required materials for a hotfix
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
Before applying a hotfix, you must obtain all required materials.
Item | Notes |
StorageGRID hotfix file |
You must download the StorageGRID hotfix file. |
See “Web browser requirements.” |
Recovery Package ( |
Before applying a hotfix, download the most recent Recovery Package file in case any problems occur during the hotfix.Then, after the hotfix has been applied, download a new copy of the Recovery Package file and save it in a safe location. The updated Recovery Package file allows you to restore the system if a failure occurs. |
Optional and used only if you are applying a hotfix manually using the SSH client. The |
Provisioning passphrase |
The passphrase is created and documented when the StorageGRID system is first installed. The provisioning passphrase is not listed in the |
Related documentation |
