Downloading the hotfix file
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
Your file is ready
You must download the hotfix file before you can apply the hotfix.
Steps
Go to the NetApp Downloads page for StorageGRID.
Select the down arrow under Available Software to see a list of hotfixes that are available to download.
Hotfix file versions have the form: 11.4.x.y. -
Review the changes that are included in the update.
If you have just recovered the primary Admin Node and you need to apply a hotfix, select the same hotfix version that is installed on the other grid nodes. -
Select the hotfix version you want to download, and select Go.
Sign in using the username and password for your NetApp account.
Read and accept the End User License Agreement.
The download page for the version you selected appears.
Download the hotfix
readme.txt
file to view a summary of the changes included in the hotfix.
Select the download button for the hotfix, and save the file.
Do not change the name of this file. If you are using a macOS device, the hotfix file might be automatically saved as a .txt
file. If it is, you must rename the file without the.txt
extension. -
Select a location for the download, and select Save.
Related information
