Troubleshooting upgrade issues
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
If the upgrade does not complete successfully, you might able to resolve the issue yourself. If you cannot resolve an issue, you should gather the required information before contacting technical support.
The following sections describe how to recover from situations where the upgrade has partially failed. Contact technical support if you cannot resolve an upgrade issue.
Upgrade precheck errors
To detect and resolve issues, you can manually run the upgrade prechecks before starting the actual upgrade. Most precheck errors provide information about how to resolve the issue. If you need help, contact technical support.
Provisioning failures
If the automatic provisioning process fails, contact technical support.
Grid node crashes or fails to start
If a grid node crashes during the upgrade process or fails to start successfully after the upgrade finishes, contact technical support to investigate and to correct any underlying issues.
Ingest or data retrieval is interrupted
If data ingest or retrieval is unexpectedly interrupted when you are not upgrading a grid node, contact technical support.
Database upgrade errors
If the database upgrade fails with an error, retry the upgrade. If it fails again, contact technical support.
