Contacting technical support
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
If you encounter errors during the grid expansion process that you are unable to resolve, or if a grid task fails, contact technical support.
When you contact technical support, you must provide the required log files to assist in troubleshooting the errors you are encountering.
Connect to the expansion node that has experienced failures:
Enter the following command:
ssh -p 8022 admin@grid_node_IP
Port 8022 is the SSH port of the base OS, while port 22 is the SSH port of the Docker container running StorageGRID. -
Enter the password listed in the
Passwords.txt
file. -
Enter the following command to switch to root:
su -
Passwords.txt
file.
Once you are logged in as root, the prompt changes from
to#
Depending on the stage the installation reached, retrieve any of the following logs that are available on the grid node:
Platform Logs VMware
/var/log/daemon.log
/var/log/storagegrid/daemon.log
/var/log/storagegrid/nodes/<node-name>.log
Linux
/etc/storagegrid/nodes/<node-name>.conf
(for each failed node) -
(for each failed node; might not exist)
