Viewing IP addresses
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
Your file is ready
You can view the IP address for each grid node in your StorageGRID system. You can then use this IP address to log into the grid node at the command line and perform various maintenance procedures.
What you'll need
You must be signed in to the Grid Manager using a supported browser.
About this task
For information on changing IP addresses, see the recovery and maintenance instructions.
Steps
Select Nodes > grid node > Overview.
Click Show more to the right of the IP Addresses title.
The IP addresses for that grid node are listed in a table.
Related information
