Defining a domain policy and registering a node
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
You need to define a domain policy that uses the TSM management class for the data saved from the Archive Node, and then register a node to use this domain policy.
Archive Node processes can leak memory if the client password for the Archive Node in Tivoli Storage Manager (TSM) expires. Ensure that the TSM server is configured so the client username/password for the Archive Node never expires. |
When registering a node on the TSM server for the use of the Archive Node (or updating an existing node), you must specify the number of mount points that the node can use for write operations by specifying the MAXNUMMP parameter to the REGISTER NODE command. The number of mount points is typically equivalent to the number of tape drive heads allocated to the Archive Node. The number specified for MAXNUMMP on the TSM server must be at least as large as the value set for the ARC > Target > Configuration > Main > Maximum Store Sessions for the Archive Node, which is set to a value of 0 or 1, as concurrent store sessions are not supported by the Archive Node.
The value of MAXSESSIONS set for the TSM server controls the maximum number of sessions that can be opened to the TSM server by all client applications. The value of MAXSESSIONS specified on the TSM must be at least as large as the value specified for ARC > Target > Configuration > Main > Number of Sessions in the Grid Manager for the Archive Node. The Archive Node concurrently creates at most one session per mount point plus a small number (< 5) of additional sessions.
The TSM node assigned to the Archive Node uses a custom domain policy tsm-domain
. The tsm-domain
domain policy is a modified version of the “standard” domain policy, configured to write to tape and with the archive destination set to be the StorageGRID system's storage pool (SGWSDiskPool
You must log in to the TSM server with administrative privileges and use the dsmadmc tool to create and activate the domain policy. |
