Viewing status indicators on the SG100 and SG1000 appliances
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
The appliance includes indicators that help you determine the status of the appliance controller and the two SSDs.
Appliance indicators and buttons
Display | State | |
1 |
Power button |
2 |
Reset button |
Use this button to perform a hard reset of the controller. |
3 |
Identify button |
This button can be set to Blink, On (Solid), or Off.
4 |
Alarm LED |
General boot-up codes
During boot-up or after a hard reset of the appliance, the following occurs:
The baseboard management controller (BMC) logs codes for the boot-up sequence, including any errors that occur.
The power button lights up.
If any errors occur during boot-up, the alarm LED lights up.
To view the boot-up and error codes, you must access the BMC interface.
SSD indicators
LED | Display | State |
1 |
Drive status/fault |
2 |
Drive active |
Blue (blinking): drive is being accessed |
