Obtaining additional equipment and tools (SG6000)
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
Before installing the StorageGRID appliance, confirm you have all of the additional equipment and tools that you need.
You need the following additional equipment to install and configure the hardware:
Screwdrivers
Phillips No. 2 screwdriver
Medium flat-blade screwdriver
ESD wrist strap
Optical cables and SFP transceivers
You need one of the following options:
One to four TwinAx cables or optical cables for the 10/25-GbE ports you plan to use on the SG6000-CN controller
One to four SFP+ transceivers for the 10/25-GbE ports if you will use optical cables and 10-GbE link speed
One to four SFP28 transceivers for the 10/25-GbE ports if you will use optical cables and 25-GbE link speed
RJ-45 (Cat5/Cat5e/Cat6) Ethernet cables
Service laptop
Supported web browser
1-GbE (RJ-45) port
Optional tools
Power drill with Phillips head bit
Flashlight
Mechanized lift for 60-drive shelves
