Setting Archive Node to read-only if TSM middleware reaches capacity
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
Your file is ready
If the targeted TSM middleware server reaches capacity, the Archive Node can be optimized to only perform retrievals.
What you'll need
You must be signed in to the Grid Manager using a supported browser.
You must have specific access permissions.
Steps
Select Support > Tools > Grid Topology.
Select Archive Node > ARC > Target.
Select Configuration > Main.
Change Maximum Retrieve Sessions to be the same as the number of concurrent sessions listed in Number of Sessions.
Change Maximum Store Sessions to 0.
Changing Maximum Store Sessions to 0 is not necessary if the Archive Node is Read-only. Store sessions will not be created. -
Click Apply Changes.
