ECOC: Corrupt Erasure Coded Data Fragment
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
Your file is ready
This audit message indicates that the system has detected a corrupt erasure-coded data fragment.
Code | Field | Description |
VCCO |
VCS ID |
The name of the VCS that contains the corrupt chunk. |
VLID |
Volume ID |
The RangeDB Volume that contains the corrupt erasure-coded fragment. |
CCID |
Chunk ID |
The identifier of the corrupt erasure-coded fragment. |
RSLT |
Result |
This field has the value 'NONE'. RSLT is a mandatory message field, but is not relevant for this particular message. 'NONE' is used rather than 'SUCS' so that this message is not filtered. |
