ECOC: Corrupt Erasure-Coded Data Fragment
This audit message indicates that the system has detected a corrupt erasure-coded data fragment.
Code Field Description
VCCO
VCS ID
The name of the VCS that contains the corrupt chunk.
VLID
Volume ID
The RangeDB Volume that contains the corrupt erasure-coded fragment.
CCID
Chunk ID
The identifier of the corrupt erasure-coded fragment.
RSLT
Result
This field has the value 'NONE'. RSLT is a mandatory message field, but is not relevant for this particular message. 'NONE' is used rather than 'SUCS' so that this message is not filtered.
