The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
ECOC: Corrupt Erasure Coded Data Fragment
PDF of this doc site
Install and upgrade
Configure and manage
Maintain
Recover nodes and maintain your grid
Creating your file...
Your file is ready
This audit message indicates that the system has detected a corrupt erasure-coded data fragment.
Code | Field | Description |
VCCO |
VCS ID |
The name of the VCS that contains the corrupt chunk. |
VLID |
Volume ID |
The RangeDB Volume that contains the corrupt erasure-coded fragment. |
CCID |
Chunk ID |
The identifier of the corrupt erasure-coded fragment. |
RSLT |
Result |
This field has the value 'NONE'. RSLT is a mandatory message field, but is not relevant for this particular message. 'NONE' is used rather than 'SUCS' so that this message is not filtered. |
