Forcing a service to terminate
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
Your file is ready
If you need to stop a service immediately, you can use the force-stop
command.
What you'll need
You must have the Passwords.txt
file.
Steps
Log in to the grid node:
Enter the following command:
ssh admin@grid_node_IP
Enter the password listed in the
Passwords.txt
file. -
Enter the following command to switch to root:
su -
Passwords.txt
file.
When you are logged in as root, the prompt changes from
to#
Manually force the service to terminate:
service servicename force-stop
For example:
service ldr force-stop
The system waits 30 seconds before terminating the service.
Log out of the command shell:
exit
