Configuring Admin proxy settings
PDF of this doc site
- Install and upgrade software
Install and maintain hardware
- SG5700 storage appliances
- SG5600 storage appliances
Configure and manage
- Administer StorageGRID
- Use StorageGRID
Monitor and troubleshoot
- Monitor a StorageGRID system
Creating your file...
If you send AutoSupport messages using HTTP or HTTPS, you can configure a non-transparent proxy server between Admin Nodes and technical support (AutoSupport).
You must have specific access permissions.
You must be signed in to the Grid Manager using a supported browser.
You can configure the settings for a single Admin proxy.
Select Configuration > Network Settings > Proxy Settings.
The Admin Proxy Settings page appears. By default, Storage is selected in the sidebar menu.
From the sidebar menu, select Admin.
Select the Enable Admin Proxy check box.
Enter the hostname or IP address of the proxy server.
Enter the port used to connect to the proxy server.
Optionally, enter the proxy username.
Leave this field blank if your proxy server does not require a username.
Optionally, enter the proxy password.
Leave this field blank if your proxy server does not require a password.
Click Save.
After the Admin proxy is saved, the proxy server between Admin Nodes and technical support is configured.
Proxy changes can take up to 10 minutes to take effect. -
If you need to disable the proxy, deselect the Enable Admin Proxy check box, and click Save.
